New Engineering, R&D content added to Kaydon Bearings website
Kaydon Corporation Bearings Division has added engineering information and an R&D and testing section to its website, www.kaydonbearings.com. Visitors to the website can learn more about how Kaydon’s exceptional engineering services help customers solve even the most demanding bearing challenges.
“Kaydon product engineers have an average of 20 years experience in bearing engineering,” said Les Miller, vice president of engineering. “They have the expertise and availability to help customers with the bearing selection and design process, from start to finish.”
Kaydon_R&D
The website’s new research, development, and testing section describes the measurement, inspection, analysis, and testing tools used by Kaydon engineers to recommend the best possible bearing solution for each customer and application.
Kaydon infinite® expertise in bearing design and manufacturing has established Kaydon as the leading thin section and slewing ring bearing remanufacturer in the world.
Kaydon Bearings is a division of Kaydon Corporation. Kaydon invented the thin section bearing and is a leading supplier of thin section, slewing ring, and remanufactured bearings.
Kaydon Corporation is a leading designer and manufacturer of custom-engineered, performance-critical products, supplying a broad and diverse group of alternative-energy, industrial, aerospace, medical, and electronic equipment, and aftermarket customers.
source: Kaydon
NSK Desenvolve Um Rolamento Autocompensador Esférico Selado De Longa Vida Com Resistência Melhorada À Abrasão Para Aplicações Da Indústria Pesada
NSK Desenvolve Um Rolamento Autocompensador Esférico Selado De Longa Vida Com Resistência Melhorada À Abrasão Para Aplicações Da Indústria Pesada(0)
NSK anunciou que desenvolveu um rolamento autocompensador esférico selado de longa vida com resistência melhorada à abrasão para aplicação em indústrias pesadas tais como mineração, fabricação de aço e ferro e fabricação de metais não ferrosos. A vida melhorada deste produto fornece aos clientes operações mais estáveis com custos de manutenção mais baixos.   Por
Rolamentos Livres de Manutenção do Apoio da Federal-Mogul  Uma das Mais Longas Pontes de Suspensão do Mundo
Rolamentos Livres de Manutenção do Apoio da Federal-Mogul Uma das Mais Longas Pontes de Suspensão do Mundo(0)
A Federal-Mogul Corporation desenvolveu os rolamentos sem necessidade de manutenção para uma das pontes de suspensão mais longas do mundo. Com a sua conclusão ainda este ano, a ponte do Fiorde de Hardanger no sudoeste da Noruega vai ser um dos maiores do mundo, consiste de 1.310 metros (4,297 pés) entre pilares. Um total de
SKF apresenta uma rede on-line desenvolvida para resolver problemas de manutenção
SKF apresenta uma rede on-line desenvolvida para resolver problemas de manutenção(0)
SKF lança hoje a Rede de Manutenção da SKF, um website permitindo que os profissionais de manutenção se conectem com outros especialistas de manutenção global e recebam sua avaliação sobre problemas específicos e encontrem possíveis soluções.  A rede de manutenção da SKF é uma maneira original, divertida e gratificante para resolver problemas. Por favor, clique
leia mais
Contatos e informações
Redes sociais
Categoria mais popular
Aviso Legal
