SKF Microlog Inspector
Incorporating SKF Microlog Inspector into your operator driven reliability (ODR) program helps maximize productivity while reducing energy costs and environmental impact.
Companies are looking wherever they can for ways to make their operations more efficient, more productive and less costly. At the same time, they face ongoing pressures to maintain high levels of worker safety while minimizing energy costs and potentially harmful environmental outcomes.
SKF_Microlog_Inspector
An increasing number of companies are turning to their front line operators to help them achieve these goals. Operator driven reliability (ODR) programs can help manufacturing facilities achieve higher levels of efficiency, reliability and safety, while at the same time contributing to a better bottom line and a reduced environmental impact. SKF’s Microlog Inspector system can be a powerful tool in supporting their condition monitoring efforts.
Because of their proximity to equipment and assets, operators are often the first to detect even slight changes in process conditions and machinery health – such as abnormal field readings, odd noises, excessive heat, vibration, leaks, unusual pressure, and even strange odors. Through an ODR program, operators can monitor a machine’s condition, manage workflow, track safety and make regulatory inspections – all in one easy-to-use system. As a result they can make significant savings in energy usage, and prove their inspection activities have saved their company money.
The SKF Microlog Inspector system is an advanced inspection system that automates paperless inspection routines, replacing and enhancing an existing data logging process for operations. User-friendly input screens facilitate accurate data recording, while alarm indicators bring awareness to abnormal conditions.
SKF Microlog Inspector can be installed on most Windows® Mobile portable devices – making it a much easier communication method. Customers can install the SKF Microlog Inspector system on multiple devices throughout their organization and download specific inspection rounds directly to the operator.
Using the SKF Microlog Inspector system as part of an overall ODR program can help a facility improve overall condition monitoring activities. Together, these two elements give front line operators powerful tools for collecting, monitoring and assessing important vibration data and energy data during inspection rounds.
SKF Microlog Inspector can transfer data over LAN, WiFi and even cellular data networks (3G/GPRS) to anywhere in the world for review and analysis by experienced maintenance engineers. In the past, such equipment relied on USB transfer alone.
SKF Microlog Inspector’s connectivity with the SKF @ptitude Monitoring Suite provides in-depth analysis and communication of machine conditions between operations, maintenance, engineering and plant management. Compliance reporting and scheduling allows for a range of collection schedules that vary from day, week, month, day of year, and multiple or repeat collections per time period. Customizable reports identify missed, overdue, out of compliance or points in alarm.
This gives customers the ability to start with an SKF Microlog Inspector system, and integrate other SKF portable and on-line condition monitoring systems as required. In addition, the SKF Microlog Inspector system can provide important support for key tasks such as work scheduling, environmental, Occupational Safety and Health Administration (OSHA) inspections, and other regulatory and safety requirements, documenting inspection data for compliance reporting and audits.
source: SKF Africa
Schaeffler apresenta o Dispositivo que permite o alinhamento rápido e fácil de uma unidade giratória
Schaeffler apresenta o Dispositivo que permite o alinhamento rápido e fácil de uma unidade giratória(0)
Foi lançado o novo dispositivo de alinhamento óptico a laser portátil que permite o alinhamento dos eixos mais rápido e facilmente de equipamentos rotativos tais como ventiladores, motores, bombas, caixa de câmbio e compressores. Por favor, clique na fonte para ler os detalhes.   source: BearingNews
Sistema de lubrificação automatizado SKF ProFlex melhora a eficiência da grua do contentor
Sistema de lubrificação automatizado SKF ProFlex melhora a eficiência da grua do contentor(0)
SKF instalou os sistemas de lubrificação automatizados SKF Proflex em gruas MSC Home Terminal no segundo maior porto da Europa, o porto de Antuérpia na Bélgica, que permite para o cliente a redução da manutenção manual em cerca de 1.900 horas por ano. Em média, o cliente gasta cerca de 90 horas para executar as
Lubrificante Food Grade Chain destina-se para esta pressão extrema
Lubrificante Food Grade Chain destina-se para esta pressão extrema(0)
Sprayon® Products, líder de longa data em fornecimento de soluções confiáveis e inovadoras para as mais exigentes aplicações de manutenção e reparo  e setoriais, orgulha-se de lançar o lubrificante LU™205 Food Grade Chain como parte da nossa extensa linha de Lubrificantes NSF® H1-Rated Food Grade.   O lubrificante LU™205 Food Grade Chain da Sprayon® é
Shell opens its largest grease plant in China
Shell opens its largest grease plant in China(0)
Royal Dutch Shell PLC (RDSB), a major supplier of lubricants in China, said that it opened the company’s largest grease plant in China. The grease plant, based in Zhuhai, a city in southern China, can produce 30,000 metric tons of grease a year, and can be expanded to 40,000 tons a year, the company said
leia mais
Contatos e informações
Redes sociais
Categoria mais popular
Aviso Legal
