In this issue we present you a wide spectrum of elements concerning the ‘bearing reliability’. The subject of ‘bearing reliability’ covers a wide range of connections and links starting from raw material till the operational environment of the bearings. Important aspects that you need to know in order to prevent unexpected damage during operation and to improve the bearing life are revealed in several topics.
The latest developments and information on the importance of bearing components (p22), and ‘the bearing silent killer’ (p72) are explained in interviews with key persons from companies active in production and operational environment of bearings. The bearing performance under contaminated lubrication conditions research results (p60) and the case study on how a failure has been avoided on a cement crusher planetary gearbox (p82) will help you enlighten the topic more in depth.
On top of all this you can check out the developments of the last six months in the bearing industry in our ‘What’s happened’ section (p28) and take a look inside the online marketplace for bearing distributors in an interview with the founders of ‘BearingStocks’ (p54).
Together with all these, many other bearing industry related topics, insights and developments can be discovered in this issue of the BearingNews magazine.
You can Subscribe here to read the FULL VERSION of the BearingNews magazine.
