NKE Austria GmbH has finished the commissioning of a new test rig for medium sized rolling bearings.
To illustrate the size of the test setup, Austrian bearing manufacturer NKE exhibited the test rig’s shaft complete with test bearings at this year’s Hannover Fair, before installing it in the new test rig.
At its headquarters in Steyr NKE operates its own test centre, which, in addition to the new RAX380 test rig for bearings of up to 380 mm, houses an RAX160 rig for testing bearings with up to 160 mm outer diameter. The test rigs yield valuable data about the tested bearings, such as their operating characteristics, wear and frictional behaviour and noise generation. In addition they allow to test the service life under the set operating conditions. At its Steyr factory NKE manufactures components for bearings from 200 mm to 800 mm diameter.
The quality and geometry of each component are tested both during and after production. Once assembled, bearing samples are subjected to function testing on the test rigs to determine their running characteristics and the interplay of their components. The running characteristics are mapped under defined load conditions with various radial and axial forces, speeds, lubricant temperatures and lubricant flow rates applied at each load level. Measured are the total frictional torque, vibration and the temperature rise on inner and outer race.
“Although we calculate the running characteristics of every bearing design, testing is important to verify that our predictions are correct”, explains Thomas Langer, Development and Testing Manager at NKE. “This helps us optimize our simulation and design process and ensure the bearings’ trouble-free operation for our customers. Furthermore vibration cannot be calculated in advance; its measurement on the final product is therefore especially important.”
In addition, the test rig is used for durability testing under operating conditions: “These long-term tests can be run at constant load or with variable load levels”, explains Thomas Langer. “To obtain statistically significant results at least five test runs under the same conditions are required. Because each of these test runs can take more than a thousand hours, durability testing with only one test rig can never be a routine operation.” For technical calculation of bearings all available resources are used, as Thomas Langer explains: “At NKE we use software guaranteeing that we adhere to the calculation methods defined in the applicable DIN ISO standards and by certification body Germanischer Lloyd.
“All NKE bearings undergo stringent, documented quality inspections at our headquarters in Steyr. Through the use of our test and measuring resources in combination with a rigorous quality policy we can guarantee that every single bearing we deliver meets the highest quality standards”, explains Harald Zerobin, Technical Managing Director at NKE. “To supplement our own inspection and test resources we also instruct external laboratories with regular and special inspection and testing. With the new test rig we can now run larger bearings under harsh operating conditions to determine their operating characteristics and demonstrate to our customers that they have made the right choice with bearings from NKE.”
Mr. René Hörwertner
NKE Austria
email: [email protected]
phone: +4372528666743
web: www.nke.at
