OAV Air Bearings, your exclusive source for high precision air bearings, now announces its latest miniature Thrust Air Bearing: “OAVTB16i04.”
Non-Contact Ultra Precision Motion
Miniature Thrust Air Bearing: “OAVTB16i04”
The OAV Thrust Air Bearing is a breakthrough innovation in air bearing technology which is capable of fully integrating a three-way frictionless surface.
OAVTB16i04 runs on a 4 mm standard shaft size with ultra-precision, zero friction motion. The C04TB1 face collar increases stiffness, prevents the shaft or bushings from moving side-to-side, and preloads opposing thin film pressure, maintaining the perfect gap and tolerances.
Click Below which you will find the information you will need to design and install OAV ® Air bearings Products.
