SKF’s Gothenburg factory has produced the company’s largest sealed spherical roller bearing (SRB) to date. The ‘241/900’ SRB is 50 per cent larger and three times heavier than the previous largest SKF sealed SRB.
Gothenburg, Sweden, 4 October 2017: Destined for a Polysius Polycom 8 roller press at a large copper mine in Peru, the three-tonne 241/900 sealed SRB is dimensionally equivalent to a standard SKF non-sealed version, with inner diameter (bore) of 900mm, outer diameter of 1,420mm and width of 515mm. The seal itself consists of a rubber over-moulded steel plate with the same profile and offering the same characteristics as those currently used with existing SKF sealed SRBs.
The actual performance of the seal for this size of SRB remains to be verified in service by the customer, but the same seal design used in smaller SRB sizes has achieved a service life of at least double that of an open, non-sealed bearing. Even longer service lives of around three to five times that of a non-sealed bearing can be achieved with SKF’s ‘Three-Barrier’ bearing protection solution, which comprises premium SKF sealed SRBs housed within sealed housings containing a barrier grease.
This record-breaking sealed SRB was designed and manufactured within a tight, six-month schedule by a team led by Daniel Ortega – Project Manager, Business Development.
Sandy Reinholdsson
Tel:+46 31 337 182; +46 724 57 18 25;
email:[email protected]
About SKF
SKF is a leading global supplier of bearings, seals, mechatronics, lubrication systems, and services which include technical support, maintenance and reliability services, engineering consulting and training. SKF is represented in more than 130 countries and has around 17,000 distributor locations worldwide. Annual sales in 2016 were SEK 72 787 million and the number of employees was 44 868. www.skf.com
